OSPFv3.ProtoMgr.AllocCfgCBfail
Description
Failed to allocate a configuration control block. The Control Block will not be created. If this operation was triggered by a MIB command then the MIB signal will be returned with a failure code. This may cause some configuration information to have to be resent.
Remedy
Investigate the source of the failure. It is probably due to a resource shortage.
Severity
Error
Message Text
%p1% failed to allocate control block type %p2% identifier %p3%.
Message Parameters
Name Type
p1 String
p2 xInt32
p3 HexByteArray
